Question on Denon 3802, 4802 specs
Discussion in 'Archived Threads 2001-2004' started by Bill Eberhardt, Aug 28, 2001.
  1. Bill Eberhardt
    Bill Eberhardt Stunt Coordinator
    May 8, 2001
    155
    I compared the 3802 and the 4802 on the Denon website and came up with the following:
    For the 3802:
    150 watts per channel (6 ohms, 1 KHz,
  2. Bill Eberhardt
    May 8, 2001
    155
    Wow, looks like I stumped the experts. I guess I'll go ahead and take the 3802 off my short-list.
  3. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    Bill,
    I think you answered your own question. If you take a look at the picture of the 4802 you see the larger transformer. I highly doubt the same transformer is used in the 3802. Got to your local dealer and have a look.
    Kevin
  4. Bryan Acevedo
    Bryan Acevedo Second Unit
    Aug 7, 2001
    290
    I agree - I have the 3802 and love it - but I wouldn't try and run 6 ohm speakers with it. It may work, but if I had the budget - the 4802 (or actually the 5800) would be the ones I would get in a heart beat.
    The power supplies in the 4802 and 5800 are much bigger than the 3802. I actually believe that the power supply in the 4802 and 5800 are exactly the same, and yet the 4802 is rated at a much lower power. I would bet that the 4802 would surpass its specs like its ancestor the 4800 did.
    Good luck!
    Bryan
  5. Bill Eberhardt
    May 8, 2001
    155
    Thanks for the help, guys. I'm looking for a 7.1 receiver or pre/pro/amp that will make me happy without going overboard on the price. I thought someone would tell me it's like comparing apples to oranges with the frequency specs on the 3802/4802, but I guess it's more like apples to lemons. [​IMG] (At least with 6 ohm speakers)
    So, I'm down to the Denon 4802 and the Outlaw 950 & 770 combination. It's too soon to decide on the Outlaw. The 770 might be too much power for the house circuit but I'll check into that when Outlaw releases it.
    I sure appreciate a forum like this with some great, knowledgeable folks to bounce some ideas around. I've learned a lot the past few months just being a fly on the wall and lurking.
