Mike Camm
- Nov 4, 2003
Hey guys ... anyone have any helpful ideas for me on building risers.. ?
Im just having trouble figuring out what to do to make them more solid and sound proof.
I am going over Terrazzo subfloors.. which might as well be marbel...unfortunately.. thx florida and your crummy soil !
Im just trying to figure out.. if I should put carpet down first..over the Terrazzo floor or maybe put down the #30 builders felt first. then build the risers ?
Or just use a nice 1/4 bead of silicone caulk on the bottom of the risers to do that "floating" thing over the Terrazzo.. and then fill between with insulation.. ?
How many sheets of plywood should I put on top ? And should I use that #30 buidlers felt between all points of wood touching wood ..
Any thoughts anyone... that the part that I am on now and I just cant make up my mind what is the best route to go?
Thanks all
Mike C
Thanks all
Mike C
