Question on analog output options for Denon DVD 1600
Discussion in 'Archived Threads 2001-2004' started by KendallT, Dec 31, 2002.
  1. KendallT
    KendallT Agent
    Aug 28, 2002
    28
    In preparation for the arrival my new Denon DVD-1600 and 3803 AVR combo I'm trying to make sue I have the cabling figured out ahead of time.
    My question is this: Will 2-channel CD audio only be output throught the 2-channel out or is it also covered by the LR portions of the 6 channel analog out for DVD-A? Note, I plan on using the 1600 as a standard CD player as well as DVD-A and DVD-V (moving the old Denon CD player into the den).
    I'd like to minimize the amount of cables and if the DVD-A outputs will also work for 2-channel CD's then I won't have to cable the 2-channel out as well. I know I could also rely on the digital out for the CD's but I hear there might be some sonic advantages to keep it on the analog side.
    Any responses would be appreciated!
    -Ken
  2. JonStern
    JonStern Agent
    Dec 5, 2002
    32
    I have the 3803 and a Sony 222 SACD player which sends its 2 channel outs to the L/R portions of the 6 channel outputs. Regarding the 1600, have you tried looking at the online manual (I just tried but the Denon site seems very slow):
    http://www.usa.denon.com/catalog/pdfs/DVD1600%20DFU.pdf
  3. KendallT
    KendallT Agent
    Aug 28, 2002
    28
    Yeah, I've downloaded and read it over but it never really answers the question. It is a slightly older manual as it doesn't depict the component video outputs now on the 1600 but I doubt the description on the audio outputs would have changed.
    Thanks for the suggestion, I wish more of the manufacturer's would put their manuals online, it's a great help.
  4. Paul Chalk
    Paul Chalk Stunt Coordinator
    Nov 16, 2001
    171
    The 2 channel outs and the Fronts on the 6 channel outs play the same thing. If you play a 2 channel source, whether it be DVD-A or CD, it will be played through both the 2 channel and 6 channel outputs. I've switched cables between the two and I can't hear any difference.
  5. EricN
    EricN Stunt Coordinator
    May 30, 2000
    71
    You will still have to have all 8 cables without switching them physically on the receiver every time you go from 2 channel to multi channel. The receiver inputs won't pull the signal from the 2 channel stereo L/R to fill in the F-L/R of the multi channel input.
    On my DVD-1600 I have 9 cables coming from it to my Denon 5800 receiver: 2 for L/R stereo, 6 for multi-channel and 1 optical for DD/DTS/PCM. WIthout all of them I would be switching cables from one format to another.
    Anyone need the web address for www.bettercables.com ? [​IMG]
  6. Chas_T
    Chas_T Supporting Actor
    Jun 1, 2002
    758
    Paul:
