Question: How to EX/ES system owners play their 5.1 Software?
Discussion in 'Archived Threads 2001-2004' started by Miles, Feb 24, 2003.
  1. Miles
    Miles Second Unit
    Jun 30, 1997
    287
    3
    I was just wondering how people with the extra speaker played 5.1 and 6.1 Encoded material?
    For example:
    Movies that aren't properly flagged but do state they are EX/ES, I would assume you force your system into DD-EX or DTS-ES mode. I think Monsters Inc. may be an example of this...
    For a 5.1 movie like Saving Private Ryan or The Matrix, do you always select EX/EX mode? Do you play with 5.1 vs ES/EX to see which sounds better? Or, does non EX/ES encoded material usually sound better as 5.1?
    Thanks for any opinions or experience as I've just started playing my new Marantz 6300 and now have a rear-center speaker.
    BTW I would think this belongs in Software not in the Hardware... but who knows...
    Miles
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,727
    470
    I moved it to the receiver/processor area because this is more of a hardware issue, and should get more input (plus there's a re-direct from the software area too).
  3. Jay Sylvester
    Jay Sylvester Supporting Actor
    Jan 27, 2002
    521
    I typically find the THX Ultra2 processing on my AVM 20 provides a more enveloping soundstage with 5.1 material, so yes, I pretty much always use the rear center speakers (I have two). Sounds that are supposed to be coming from the rear center only are also a bit more anchored to the rear, rather than being too floaty.
    I've actually read that DTS recommends you always turn on DTS-ES matrix with their 5.1 soundtracks.
  4. Dmitry
    Dmitry Supporting Actor
    Nov 30, 1998
    740
    I play it by ear — some titles get too "rear-center" heave in EX mode. The most recent example was Predator 2 , where I just couldn't stand the EX processing. This all applies to Dolby, I haven't tried with DTS yet.
  5. Scott Merryfield
    Dec 16, 1998
    12,080
    934
    I have also been using the THX Ultra 2 processing on most 5.1 source material. I have yet to find a soundtrack that has been too "rear center" oriented in this mode.
  6. Jeff Kohn
    Jeff Kohn Supporting Actor
    Dec 29, 2001
    680
    My Rotel 1066 has a proprietary processing mode to create a center back channel for 5.1 sources. I prefer this mode over DD-EX for 5.1 sources because it doesn't have the tendency to collapse the rear soundstage to the center back the way that DD-EX processing does on 5.1 sources. RS processing sounds much better IMHO. (Although for true EX soundtracks I'll use DD-EX since it works better for those).
  7. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    The Rotel has xS modes, and the Outlaw 950 that I have, has mostly equivalent CES modes. Both pre/pros use the same Cirrus DSP engine. The Rotel supposedly puts out non-mono rears, but you only get mono for the 950.
    So for marked DTS-ES and DD EX movies, I use DTS-ES and DD EX, but for all other "std" DD/DTS soundtracks, I use the CES version which gives me 7.1 playback. There are movies out there that I know are 6.1 (Pitch Black for example), that aren't marked anywhere on the DVD itself.
  8. Ottis Fletcher
    Ottis Fletcher Stunt Coordinator
    May 16, 2002
    122
    I have 7.1 EX/ES set up. My receiver does an excellent job a matrixing the back surrounds on 5.1 material. On 6.1 it plays the 6th channel out of the 2 back speakers, which IMO sounds better then 1 back channel with 6.1 material. So I all ways leave the EX/ES on.
  9. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    I always leave EX or ES turned on, have yet to find a 5.1 source that doesn't sound better this way (but I don't have Predator 2).
  10. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    I leave my rear centers on, as well. I haven't yet come across a DVD that didn't sound better that way.
    DJ
  11. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Those of you who like to use 6/7.1 implementation of 5.1 movies,should play the Dolby trailer called "canyon",and post what you think of the "effect".
  12. Sebastien David
    Sebastien David Second Unit
    Dec 4, 2001
    291
    I think it heavily depends on your setup.
    I have found that generally, in a 6.1 setup where the "side surrounds" are in fact positioned more towards the rear (my setup, temporarily), non-EX/ES sources sound too rear-centered when matrix processing is applied. it may also be related to the fact that rear center speaker is much closer than the other two, however I have calibrated it.
    But I tried briefly playing with the positioning of my speakers, and using 4 speakers in the back in a proper "7.1" setup with the side surrounds actually positioned to the sides, "7.1" extracted from 5.1 sounds very good, much better than in a 6.1 setup, but curiously, not that much better than in a conventional 5.1 setup.
    It will also depend on the speaker type you are using, most likely. Using a dipole speaker in the rear center position would most likely result in a lot less "rear-centering" since the sound coming from it would be more diffuse. I have not tried that, however, so I can't know for sure.
  13. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    I leave EX/ES on all the time, because my side surrounds are only about a foot behind the listening position. The rear center really fills the space and gives it a more cohesive rear soundstage. But it's more a result of the strange room I'm dealing with, so your mileage may vary.
