Question for yamaha 2095 owners
Discussion in 'Archived Threads 2001-2004' started by Mike Eriquez, Sep 1, 2001.
  1. Mike Eriquez
    Mike Eriquez Auditioning
    Dec 10, 1998
    11
    I woundering about the dynamic range. Should it be set to max or std. It's a little confusing the way the manual reads. Thanks for any help you can give.
  2. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    I believe this should be set to "max"...this way there is no limitations to the reproduced dynamic range. You would only lower it if you wanted to listen at lower volume levels (late at night for instance).
  3. Massimo N
    Massimo N Stunt Coordinator
    Oct 23, 2000
    174
    Set to "max." "Normal & Min" reduce the dynamic range.
    Mass
  4. Han
    Han Second Unit
    Jan 13, 2001
    262
    I had mine on max for a couple of years, but I changed to standard for the rest of the time that it was my main receiver. I just couldn't take fiddling with the volume control much more in quiet scenes of some DVDs and then turning the volume back down when it gets loud. Now that I use an HK 310 as a preamp for my Anthem amp, I have to use HK's version of dynamic compression so as to hear everything, but not disturb the neighbors. I've tried the HK at full range, and I think it's slightly better at handling quiet scenes. No hard data, just some limited observations.
