question for vsx-ds811s users..... (1 Viewer)
MarcWi
Is et up my new system over the weekend and I'm loving it! Thanks for everyone who as answered questions in my planning stages! now that im set up-I was sondering which settings VSX-d811s users preferred and for which sources. This thing has some many options Im overwhelemd!
Thanks!
ChadLB
For regular cd's and sports I like 5-channel stereo. For watching TV I like PLII Music over PLII Movie mode. I usually always have the loudness button on also.
MarcWi
do you use the dynamic range limiter? I enabled it as I was watching T2 and the dream sequence ramped up in volume so much the house shook. Also what does the loudness setting actually do?
ChadLB
When you say dynamic range limiter are you refering to the LFE attenuator that can be 0,5, or 10?
The loudness mode increases the bass/treble a little. If you turn that on while listening to anything you should notice a difference.
MarcWi
thanks for the input--it is the dynamic range option-not LFE. It limits the range that the volume can differ. I set it to medium.
TheThrillisgone
