Question for those who used rigid foam to insulate a basement
Discussion in 'Home Theater Projects' started by Luke_Y, Mar 25, 2006.
  1. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    I plan to insulate the poured concrete walls in my basement with rigid XPS foam. If you have used this method, what did you use for adhesive? How long did it take to set-up and hold the panels in place? What did you use to hold them until the adhesive set-up?
    I wont be able to friction fit them top and bottom as there is a 1ft high knee wall (dont know what else to call it) at the top of my poured wall before the 1st level floor joists to give the basement an extra foot of depth. I will have to insulate that area differently so the panels will only go to the top of the concrete.
  2. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    Anyone..... ? [​IMG]
  3. DaveHo
    DaveHo Supporting Actor
    Dec 11, 2001
    605
    There is a Liquid Nails product designed for foam. It'll be sticky enough to hold the panels until it sets. You shouldn't need to do anything other than pressing the panel to the wall.
    -Dave
  4. MarkMel
    MarkMel Screenwriter
    Nov 19, 2003
    1,869
    115
    1,610
    When you use liquid nails, there is one thing you can do to facilitate curing. Squirt out a nice pattern on the back of your foam. Push it into place. Pull the panel back off, this will flash cure it. Then put it back into position. I think it may explain this on the tube.
  5. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    Thanks guys. Whats the cleanest way to cut this stuff? Can you score it and snap it sort of like drywall, or do you have to cut it all the way through with something?
  6. MarkMel
    Nov 19, 2003
    1,869
    115
    1,610
    From Corning;
    FOAMULAR® rigid foam insulation contains literally hundreds of millions of densely packed air cells. Since air is nature's most effective insulator, the sheer volume of this compressed trapped air gives FOAMULAR insulation exceptional thermal performance.
    FOAMULAR is also "hydrophobic," meaning it's practically impossible for it to be penetrated by moisture. Moisture penetration can cause a permanent loss of R-value, and after repeated penetration the insulation can be practically useless.
    If you're installing FOAMULAR insulation yourself, you should know that it weighs considerably less than plywood, OSB or other non-insulation material so it's easier, faster and safer to install. Plus, the product's built-in rigidity means it can be scored and snapped, cut, or sawed with common tools. Sagging and settling are never a problem. We also offer PROPINK® insulating sheathing which is manufactured with extra toughness for new construction applications. Complete installation instructions are available by clicking on the applications for each FOAMULAR product listed below.
  7. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    I have another question.
    I purchased STYROFOAM Residential Sheathing extruded polystyrene insulation. The foam insulation board has a thin plastic film on both sides. No-one had the plain STYROFOAM Tongue and Groove extruded polystyrene without the plastic film on both sides. The sales people at all the stores said it was the same stuff other than the plastic film. the DOW website says the plastic film reduces job site damage to the insulation boards.
    My question is, do I remove the plastic film on both sides or at least the side that I am gluing to the concrete walls? It is already slightly peeling on the edges and I cant imagine the adhesive will hold the best.
    This is the stuff: Link
    Was told its the same as this: (except for the thin plastic film) Link
  8. JeffCar
    JeffCar Agent
    Feb 20, 2006
    29
    I used Liquid Nails (the one specially formulated for foam is the only one to use... the rest will eat through the foam. Lay on a good pattern and press. It had no trouble holding to my poured walls.
    Jeff
