Roger P
- Apr 9, 2002
What do you have yours set up at? I have it at "Low" and I'm not sure if that's good or not.
Use the "Warm" color temp mode, as it is the closest to the D6,500 standard.For the record, and it may vary by model, but out of the box, the "cool" color temperature setting on my 36" WEGA was much closer to 6500K than the other two. You can usually get a feel for which is closest by watching B&W material, flipping through the three color temp modes, and choosing the one that looks the most neutral. Make sure your TV is warmed up for a half hour or so before you make this decision, though. The differences are not usually subtle with the factory settings.
