question for Silent Hill 2 owners (Xbox)
Discussion in 'Archived Threads 2001-2004' started by Sean Patrick, Nov 20, 2002.
  1. Sean Patrick
    Sean Patrick Supporting Actor
    Apr 22, 1999
    732
    i have a 16:9 tv that locks into "full" with 480p signal, which Silent Hill 2 supports.
    i bought the xbox version so i could turn off the "noise filter", but have found that much of the text rolls off the edges of the screen, especially the title screen.
    I don't have THAT much overscan on my tv - has anyone else had this problem? it just doesn't seem to fit the screen right.
    thanks
  2. Micheal
    Micheal Screenwriter
    Apr 13, 1999
    1,523
    I didn't have any problems playing it on my Toshiba (16:9) 40x81?
  3. Scott Bourden
    Scott Bourden Second Unit
    Aug 29, 2001
    457
  4. Micheal
    Apr 13, 1999
    1,523
    Thanks, I'll have to check that out![​IMG]
  5. Sean Patrick
    Apr 22, 1999
    732
    so on the main title screen, you guys aren't seeing the edges of the "S" and "2" cut off of the title?
  6. Sean Patrick
    Apr 22, 1999
    732
    by the way - to get to the secret menu to turn off noise filter - press both triggers when in the option menu.
    taking off the noise filter is a REVELATION.
