1. Sign-up to become a member, and all the ads between posts will disappear. It only takes 30 seconds to sign up, so why not do it now!
Question for Polk CS400i center channel owners
Discussion in 'Archived Threads 2001-2004' started by Allen Longcor, Dec 16, 2001.
  1. Allen Longcor
    Allen Longcor Supporting Actor
    Oct 21, 2001
    549
    110
    There are two sets of binding posts for bi-wiring/bi-amping, but if I am not going to do that then does it matter which set I use? It doesn't say anything in the manual about it.
  2. TimGruwell
    TimGruwell Auditioning
    Nov 28, 2001
    4
    Allen,
    As long as you leave the jumper between the post, it does not matter which set you connect it up to. I think I remember reading that the top ones are for the Tweeter and the bottom ones are for the mids. Hope this helps!
    Tim
  3. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    Tim is correct; with jumper in place it matters not. With the jumper gone, the top set runs to the tweeter and the bottom set runs to the woofs.
  4. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    I've heard of some people connecting to the tweeter posts because it sounds better. This is because the jumpers aren't as good conductors as copper wire, so better to connect directly to the tweeter and let the woofers get the "leftovers." Go figure [​IMG]
  5. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
  6. Jonathan_M
    Jonathan_M Stunt Coordinator
    May 8, 2001
    89
    I would suggest connecting to both sets of posts and doing an A/B test on the same audio source to see which you prefer.
  7. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    Or bi-wire and see what you like. Its in the manual.
