charles_w
- May 11, 2001
Eric,
Eric am I understanding your method of using danish oil by applying the oil with sandpaper?
If so do you sand between coats or is the sanding while applying oil?
Excellent craftsmanship BTW.
Thanks, Lee
Thanks, Lee
