Question for Denon 3802 owners-- HELP!
Discussion in 'Archived Threads 2001-2004' started by Dan Hitchman, Aug 4, 2001.
  1. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    Just got done reading the online manual for the Denon 3802. It's not well written at all, so I have a question in need of a quick answer. [​IMG]
    In the speaker set up mode can I adjust each center back surround speaker separately for time delay (distance setting) and volume (or is it a global setting for both center back speakers-- hopefully not)? It would be running only the standard 7.1 speaker array (no surround A and B, just one pair).
    Thanks!
    Dan
    Stop HDCP and 5C-- Your rights are at risk!
  2. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Dan I only have the 3801,but I doubt they would change something like that for the worse,so the answer is yes,you can assign a different value for speaker distance,and volume setting for any of the 9 speakers that are avilable.
    "You Hungarians always disagree"
    [Edited last by Lewis Besze on August 04, 2001 at 01:36 PM]
  3. Matt Parsons
    Matt Parsons Stunt Coordinator
    Mar 18, 2001
    68
    Dan,
    I just got my 3802 on Weds and went through this whole process - YES, you can definitely adjust for channel level and delay for each of the 2 surround back speakers.
  4. Dan Hitchman
    Jun 11, 1999
    2,713
    Thanks guys!
    Dan
  5. Trevor Schell
    Trevor Schell Supporting Actor
    Jan 6, 1999
    511
    Planning on picking up a 3802 Dan. [​IMG]
    The 5800 is designed the same way as mentioned by Lewis.
    Trevor..[​IMG]
    My HomeTheater S.E. Sonically Enhanced
    Updated new digital pictures!
  6. Dan Hitchman
    Jun 11, 1999
    2,713
    Actually, I'm looking into this for a neighbor. My sights are on the Outlaw Model 950 pre-amp if it gets good reviews.
    I hope O.A. can work miracles with an $899 product. [​IMG]
    Dan
  7. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Trevor, are you going to wait for a Canuck release of the Denon 3802, or are you going to check out the internet mail-order scene? I myself am seriously considering the Denon 3802, but its a long 3 months or so wait! I am checking out ordering from the US. Warranty won't work though.
  8. Trevor Schell
    Jan 6, 1999
    511
    Chris,,I would wait and get the 3802 locally. Ordering a receiver Online without a warrenty is too much of a risk..I tried it earlier this year in my search for a good price on the 5800. It did not pan out the way that I had hoped. I ended up getting one locally and couldn't be happier with the quality receiver and peice of mind knowing I can get service without hassle.
    Something to consider.
    Trevor..[​IMG]
