Question for any Rotel RSP 1068 owner
Discussion in 'AV Receivers' started by StanB, Jan 27, 2006.
  1. StanB
    StanB Agent
    Jun 19, 2005
    27
    I have a Rotel RSP 1068 HT processor and a 6.1 system. I would like to have different configurations for movies and music. For movies I want to use my rear speaker (6.1). For music, I do not want my rear speaker active. I just want 5.1 for music. Can I set up my 1068 this way? If so, how? If not, is there a processor that lets you do this?
    Thanks for any help on this.
  2. JessyMcK
    JessyMcK Agent
    Dec 3, 2004
    45
    5.1 would be using your rear speakers. 2.1 is front and sub only.
  3. StanB
    StanB Agent
    Jun 19, 2005
    27
    I have 2 fronts, 1 center, 2 sides and 1 rear. Actually Rotel calls them front, center, surround and back speakers. The back speaker is want I want with movies but not with music.
  4. Jasen Chandler
    Jasen Chandler Stunt Coordinator
    Sep 16, 2001
    91
    Unless you tell it to matrix a 5.1 source to 6.1 is should play it without the back center.
  5. StanB
    StanB Agent
    Jun 19, 2005
    27
    I often play 2 channel stereo CD's using DTS Neo 6. Unless I go into the setup and deactivate the back channel, it plays 6.1, which is what I do not want. I really don't like music coming from the back of my head. I guess I'd like the option of having an automatically deactivated back channel when playing Neo 6, and an activate back channel for movies.
