Question about Z-1/Boxlite Matinee.
Discussion in 'Displays' started by Mark Beise, Sep 18, 2003.
  1. Mark Beise
    Mark Beise Agent
    Feb 13, 1999
    27
    How am I able to hook up an HDTV tuner/receiver and DVD player with component inputs to the projector at the same time?
  2. mark alan
    mark alan Supporting Actor
    Nov 19, 2002
    620
    You need a component switch. You can either go out and spend $200-$300 for a fancy switch,....
    or
    you can go get this for $20.
    It is for composite video and left/right stereo connections, but it is a mechanical switch with an unlimited bandwidth. Just plug your three component lines into the video and audio RCA connections on the switcher. Supposedly, you should put the Y (green) cable into the video connection, since the Y line carries the full horizontal resolution, and has a higher bandwidth requirment.
    I use this for my Z1 and dvd and hd receiver, and there is no picture degredation vs a straight component connection from the source to the projector.
  3. Mark Beise
    Mark Beise Agent
    Feb 13, 1999
    27
    Exactly what I was looking for. Thanks Mark [​IMG] .
  4. mark alan
    Nov 19, 2002
    620
    always glad to help a fellow Mark.
    Let me know how it works for you.
