Question about wiring a dc fan
Discussion in 'Archived Threads 2001-2004' started by Jim Tressler, Jan 26, 2002.
  1. Jim Tressler
    Jim Tressler Stunt Coordinator
    Dec 12, 2001
    207
    Hello all,
    I am about to install a small pc fan in my HT to cool it off a bit. Question on the AC/DC adapter: If the fan is rated at 12volts and 100mA , will an AC/DC adapter that is "rated" at 300mA be ok? or do I need to find one that is 100mA? or is it ok as long as the adapter is "rated" at 100mA or higher?
    thanks!
    Jim
  2. Jim Mc
    Jim Mc Agent
    Sep 3, 2000
    27
    The fan rated at 12volts and 100mA means the fan needs 12v and draws up to 100mA. The power adapter rated at 300mA means it is has the capacity of up to 300mA. Assuming the adapter is 12v out which you did not actually say. You are all set.
    Jim Mc
    The Stargate
    http://www.ofoto.com/I.jsp?m=66116202303&n=1123730486
  3. Jim Tressler
    Dec 12, 2001
    207
    Thanks for the info Jim! - Yes the adapter is 12volt, 300mA.
    Jim
    btw.. excellent HT setup [​IMG]
