Question about TV Antennas and Reception
Discussion in 'Displays' started by Yoshi Sugawara, Dec 25, 2003.
  1. Yoshi Sugawara
    Yoshi Sugawara Stunt Coordinator
    Nov 13, 2000
    206
    My fiance called me all the way from Japan (visiting her parents) and asked me to post a question in the HTF [​IMG]
    She wanted to ask about powered TV antennas and whether they help in her parents' situation or not. The thing is, her parents live in a mountainous area, and I'm not sure if an antenna (even powered ones) would help in getting any kind of TV transmission.
    Do any of you live in a semi-remote area sourrounded by mountains - is cable/satellite the only option for watching TV?
  2. MikeTz
    MikeTz Stunt Coordinator
    Mar 7, 2003
    146
    The problem with mountainous areas is that it may be impossible to locate the TV antenna at a point where there is "line-of-sight" to a TV transmitter. If this is the case, then an amplified (or powered) antenna would not help because there is no signal to amplify. If the TV signal is weak (you can see video on the TV but there is a lot of snow) then an amplified antenna might work.
    Satellite systems work best in remote areas or places where line-of-sight to a terrestrial TV transmitter cannot be established. That's because the satellite signal is coming from above the earth and it's easier to establish line-of-sight to the receiveing antenna versus a TV transmitter that is land based.
    MT
