Question about TV and Stereo hookup with DVD (1 Viewer)
Lee Scoggins
Atlanta, Georgia
Lee
Friends,
I am stumped by a simple HT setup I am working on with my friend. He has a Sony DVD player the 500NVP (I think) and we hooked it up to a 27 inch Sony Wega 26FS13(both brand new, out of the box).
Here's the problem:
we want to allow my friend to switch between audio coming from the DVD to the TV and from the DVD going to the Stereo. His stereo is a older pre-amp and amp (Carver) and Klipsch speakers, sounds fairly good for its age.
We connected the TV audio outputs to DVD player Line 1 (L/R) and the stereo audio interconnects to DVD player Line 2 (L/R). We can't for the life of us figure out how to switch between the two audio lines. The owner's manual (on the DVD, but TV is no help either) is heavily geared to a receiver set-up and seems to not provide an answer.
Any solution? Any ideas?
Otherwise the video performance is amazing. He is very happy but we would like to be able to choose TV sound or stereo sound.
Thanks for your help...:)
Lee
Lee Scoggins
Atlanta, Georgia
Lee
David,
My mistake. I did connect them to the TV input. This is not the problem, however. The TV has sound from the DVD player and it plays just fine. I just can't get the Line 2 option to send the audio signal to the stereo system.
Any ideas?
Lee
David Judah
If the Sony won't output two audio lines out at the same time, you could always run into the TV and then TV audio out to the stereo.
DJ
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Lee, your post is a little vague:
As best as I can tell, your friend wants to be able to watch DVDs with the stereo on, or just with the TV on?
All you need to do is send the stereo audio interconnects to both Line 1 and Line 2.
Oh, sorry! :D What I meant was, all you need to do is split the DVD player’s audio outputs and send audio to both the TV and the stereo. All you need to accomplish this is a pair of RCA “y” splitters (1 male to 2 female).
Wayne A. Pflughaupt
Ken Seeber
Most of Sony's DVD players have two sets of analog outputs, both of which are active all the time. There's no need for switching at all.
I have to agree with Wayne, your post is worded very confusingly. Can you take a deep breath and clarify for us?
Lee Scoggins
Atlanta, Georgia
Lee
Ken,
I clarified the post to show I was talking about DVD player Line 1 and Line 2.
I went to my trusty dealer yesterday and it appears that Line 2 audio outputs are in fact dead on this model Sony (and several others in the shop) so I thing the answer is to send the audio from a TV audio out to the stereo.
I think Sony has installed dummy terminals on this unit for some reason. We can tell this from volt meter readings on the unit.
Lee
Hi Lee,
I don't know if this will help. I have an older sony tv, hooked up as you have just proposed. DVD player audio to the tv and audio out of the tv to the receiver. With this setup the DVD player will normally play audio through the tv. In order to have audio sent to the receiver the sound must be disabled in the tv setup menu. On my tv (older 32" sony) I have to push the menu button to access the menu choices. Choose audio - choose spewaker switch (which at this point says ON) and change it to OFF. The tv sound will be off and the DVD audio will be routed through the tv out to the receiver. It could be a little tedious, but it works. I hope this is helpful. :)
Ken Seeber
Lee, if the output jacks are dead, there is a problem with the player that Sony should repair for free if it's still under warranty. Sony does not intentionally install inactive outputs on its players.
Lee Scoggins
Atlanta, Georgia
Lee
Ken,
I'm inclined to believe this statement as a Sony fan (at least on source components), however the volt meter readings do not lie and we took them on several new units.
Perhaps they have to be activated in a way the Fluke meter did not pick up.
Lee
Ken Seeber
If that's the case, Lee, then I would first read the owner's manual and make sure you don't have to turn the outputs on using the menu system somehow. Then I'd call Sony and ask, because I'm using both sets of my Sony player's analog audio output jacks.
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
As I noted before, Lee, you don’t need two sets of audio outs on the DVD player to accomplish your objective. You can easily split a single audio output with a pair of RCA “y” adapters.
Wayne A. Pflughaupt
acinstallation921
