Brandon WB
Grip
- Feb 12, 2004
Any comments on this would be greatly appreciated.
I have the B&K ref 200.3 for my front 3 speakers hooked up to a yamaha receiver as my processor. When I first go to turn on the amp, after all other components are switched on first (B&K recommends), I get a 1 second fairly loud hissing or static sound out of only the left front tower speaker. It then goes away and sounds fine thereafter. It's like all the power momentarily goes thru just that speaker with no other signal, and then disappears. I have checked all connections for that speaker and there's no short or fault there. My question is, is this normal or harmful? If so what do I do, or what do I look for?
Brandon
Brandon
