Question about the double sided widescreen/fullscreen discs.
Discussion in 'Archived Threads 2001-2004' started by StephenA, Jan 13, 2003.
  1. StephenA
    StephenA Screenwriter
    Nov 30, 2001
    1,512
    Ok, here's my question. Why is it that when I put in the disc to watch it, I have to put the widescreen side up to view the movie in widescreen? If I watch a single sided disc with the artwork on the other side, I keep the data side down to watch it. I don't really get this.
  2. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    It saying "if you see this label, you're watching the widescreen version."
  3. Dan M
    Dan M Second Unit
    Feb 6, 2000
    327
    Lessee....okay, the side that is labeled widescreen is actually fullscreen because the data side is read by the laser from the bottom. But it's labeled backwards so that when you insert the disc the label is facing up and towards you.
    Make sense?
  4. Brian McHale
    Brian McHale Supporting Actor
    Dec 5, 1999
    514
    12
    Brian McHale
    Since people are used to putting the artwork side up, they label two-sided discs so you watch the version according to the up-side labeling. The side that says WIDESCREEN actually contains the FULL SCREEN version.
  5. StephenA
    Nov 30, 2001
    1,512
    Ok, thanks guys. I guess I was a little confused. :b Dunno why I didn't think of that before.
  6. BrettB
    BrettB Producer
    Feb 1, 2001
    3,019
    Well, that's just the way it is.
    1. Pretend it is a single-sided disc with only the widescreeen version.
    2. Imagine that instead of the small "Widescreen" text around the hub there is instead artwork covering that side of the disc.
    I assume you could use magic markers and create your own artwork without harming the "good" side of the disc. [​IMG]
  7. Martin Fontaine
    Martin Fontaine Supporting Actor
    Aug 15, 2001
    626
    The Good Girl is the other way around.
    When I first put the disk in, I put the side that says Widescreen on top and I see the dreaded message! Flip the disk and it's fine (Well, ok, the WS Side was defective on my first copy before I exchanged it) But the new version also has the labelling backwards. Didn't freeze where the 1st copy did, but I haven't watched it in whole with the new copy yet.
