Chris_harpua
- Feb 24, 2004
I am going to be purchasing a new television in the next few months and am on a tight budget. I will only have about $300 to spend on a tv and I noticed a 31" Sanyo for about $280 at Walmart to replace my 6 year old 20" Panasonic. It has an s-video connection but no component connection. I am going to connect my Sony DVD player to this television and want to upgrade from the composite connection im using now. My question is, if I am not using an HD television and will not be using progressive scan (im assuming that plain televisions dont support progressive scan and that only hd ones will), will I notice a large difference between the s-video and component connections? is there that big of a difference if not using progressive scan? if not then im going for the Sanyo because its right in my budget at this time. I wont be able to afford anything more than that cuz I need a new entertainment center as well, mine only holds up to a 27" and I would like bigger than that. Thanks for any help you can give me.
