Question about speakers placement for my Paradigm Studio 40!
Discussion in 'Archived Threads 2001-2004' started by michael_tran, Aug 16, 2002.
  1. michael_tran
    michael_tran Agent
    May 28, 2002
    34
    Hello guys,
    We have an entertainment build in from the house forced me to put the Studio 40 up about 5 feet tall and the listening area is about 12 feet away, I saw somewhere someone suggest that if I have to put it up that high I need to turn the speaker upside down? is it true? need some suggestions here, thanks
  2. Shawn Solar
    Shawn Solar Supporting Actor
    May 12, 2001
    763
    If at all possible I would tilt the speaker down a little bit with the speaker upright. Now is that 5ft to the tweeter or 5ft to the bottom of the speaker. You can turn it upside down, but Its hard to say whether it will sound good. Laying it on its side is another option if you can. Try all of them and experiment for best results.
  3. michael_tran
    michael_tran Agent
    May 28, 2002
    34
    Shawn,
    It is 5ft to the bottom of the speaker, so what you saying is you still prefer to have speaker on their 'standard' upright?
  4. Shawn Solar
    May 12, 2001
    763
    It's really a judgement call. I say try them tilted down toward the floor, maybe a couple of inches. That should make the sound more direct. You can try to flip them but they will then still over your head sitting down. I also would try them on there side and add a slight angle. Either way I think the only way to improve the sound is to get them pointed a bit more towards the listener. Firing straight 5-7ft above your head will dull the high end and kill imaging as you basically relying on room reflections for the treble.
  5. James Bergeron
    James Bergeron Supporting Actor
    Oct 9, 2001
    831
    Ummm that would be VERY difficult to flip the Studio 40's they are rounded on the top and will not sit properly. 5 feet to the bottom is a little high, I have mine pretty high, about 42" to the bottom I believe. They sound fine like this in my room.
