Matt_Smi
- Apr 11, 2004
- blank
Ok here is the deal I plan on calibrating my setup soon, but I have a concern as I have two listening positions in my room. Look at the link below to see a room diagram to know what I am talking about, I also linked to a few outdated pictures of my room so you can see what its like. I (or my friends) listen to movies on either the papason chair or the couch. You need to calibrate your system from your listening position, so which one should I calibrate from? I would say that most of the time when watching a movie alone it sit mainly in the chair as it is closer to my TV. I usually also pull the papason chair out from the wall a bit so it is centered between the speakers better. If I calibrate from the chair will things sound off from the couch? I doubt it and I bet it will sound better than it does now regardless, but still. Another thing I was thinking of was calibrating at the midpoint between the chair and couch, but I don’t know if this would work well, as it would be right near the sub (which is right behind the papason chair). Anyway what would you recommend doing?
Room Diagram
http://images.cardomain.com/member_i.../439698_16.jpg
Front of Room
http://images.cardomain.com/member_i...98_19_full.jpg
Back of Room
http://images.cardomain.com/member_i...98_18_full.jpg
Room Diagram
Front of Room
Back of Room
