Question about speaker cable lengths
Discussion in 'Archived Threads 2001-2004' started by Allen Longcor, Jun 24, 2002.
  1. Allen Longcor
    Allen Longcor Supporting Actor
    Oct 21, 2001
    549
    110
    Ok even if I heard no difference, would you guys recommend having the same lengths for the front soundstage, or just the left and right fronts?
    Also, if you could, would you have all 5 speaker cable lengths the same, or would you just have the front three the same, and the back two the same.
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    whatever you feel like will be fine. equal lengths are not much of an issue, just leave a little extra to allow for some flexibility in positioning or repositioning.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Most people believe it's a very bad thing to leave coils of speaker wire behind your equipment. So it's actually DAMAGING to your sound to try and cut all 3 speaker wires the same length if it means lots of slack.
    (Think of a long coil of wire as being an antenna. And you have lots of AC power cords nearby that generate a very dirty 60 hz signal. It's just looking for a nice piece of wire to couple with. [​IMG] )
    It's a bit of a myth that the speaker wires should all be the same length. For video signals on a 3-wire component cable set that go up to 4 Mhz, a few inches difference is a lot. But audio would take about 80 feet of difference to make a 1% phase shift.
  4. Allen Longcor
    Oct 21, 2001
    549
    110
    OH. Shoot hehehe. What if there were coils of wire, but it was not behind electric equipment or anything. Would that be ok or should I cut the wire down?
  5. Jeff Mills
    Jeff Mills Stunt Coordinator
    Feb 8, 2002
    95
    By coiling wire you are creating an inductor, your best bet is to trim it to length with about a foot or 2 of slack. Dont coil large amounts of speaker wire.
  6. Allen Longcor
    Oct 21, 2001
    549
    110
    Alright, thanks guys. I'll trim down all that stuff today.
  7. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Jeff, your statment
  8. Jeff Mills
    Feb 8, 2002
    95
    Thanks for the insight chu, I was previously unaware that the opposing flows would cancel the inductance created by the coil.
    I beleive it was here that I heard the previous information.
  9. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    I believe coiling speaker cable may cause it to pick up RF - or so I've heard. Some people reported hearing radio stations on their speakers, which went away when they uncoiled their cables. No idea how true that is, or how close they lived to a radio transmitter, etc.
    Oops... Chu already mentioned RFI... hmm, hang on. Those two are completely contradictory to each other, right? A coil can't both act as an inductor and pick up RFI [​IMG]
  10. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Hey Saurav, you've heard about the person who has a coffee maker and swears its communicating with the spirit world?
  11. Saurav
    Feb 15, 2001
    2,174
  12. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
  13. Saurav
    Feb 15, 2001
    2,174
    OK, I have to hand it to you for that one [​IMG]
