Question about Sony FV service menus (1 Viewer)
Tony_Pat
Specifically, does the 32FV27 have separate service controls for Brightness, Picture, Tint, Detail for each source input?
SteveK
Tony- I don't know about the FV series, but the FS series doesn't have separate settings for each input; however, you can use the various picture settings (standard, vivid, movie, etc) in this way if you wish. For example, use "movie" for your DVD player, "Standard" for cable, etc. I only use the "movie" setting for all my inputs, but that is probably not optimal.
Steve K.
Tony_Pat
Hmm, so which setting do the service codes affect? Or rather, if I make service code adjustments does it affect all modes relative to how they are "tuned"?
Is there a place that defines what the differences are between the various Picture Settings?
OttoIsHere
