Question about soldering my own cables
Discussion in 'Archived Threads 2001-2004' started by Jonathan Burk, Oct 2, 2001.
  1. Jonathan Burk
    Jonathan Burk Second Unit
    May 31, 1999
    452
    4
    Castaic, CA
    Jonathan Burk
    I'm going to start making cables, and I need to know 2 things.
    1. What wattage soldering iron do I need?
    2. What kind of solder?
    It will mostly be RCA plugs for audio and video.
    Thanks.
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Gee, I thought that someone else would have answered by now. (I don't have the final word). Radio Shack is the best place to go. Just get a pencil type iron that you can change elements on. (They unscrew w/various wattages). I think 25 watts should do it, but I'm not positive on that.
    As for solder, the usual combinations are anywhere between 40/60 to 60/40. Any of those should work.
    On a final note, I do hope that this won't be your first soldering job. Just remember to heat the wire, and when the wire gets hot enough, the solder will melt.
    Glenn
