Question about SATA + IDE Harddrives
Discussion in 'Computers' started by Scott L, Jul 26, 2004.
  1. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    I'm craving more space again. I have 2 hd's and 1 disc drive on the IDE channels, leaving 1 open. Rather than getting a cable that will reach can I just go SATA on top of the two existing IDE HDs?
    Motherboard is an Asus with the i865PE chipset.
  2. JamesMH
    JamesMH Stunt Coordinator
    Mar 8, 1999
    74
    Is this the one you have?
    http://usa.asus.com/prog/spec.asp?m=P4P800&langs=09 , or the deluxe version.
    It looks like you can.
    2 x UltraDMA 100/66/33
    2 x Serial ATA, RAID 0 (Microsoft WinXP only)
    Take a look in your bios too.
    I have a Abit IC7-G board, I only have one SATA Hitachi 160GB drive, plus a DVD writer on IDE1 and a CDROM on IDE2. Similar to what you want to do.
  3. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    Yes the SATA ports use their own controller so you'll be able to use the IDE ports in conjuntion with the SATA ports.
  4. MikeH
    MikeH Stunt Coordinator
    Nov 22, 1999
    170
    110
    Does the SATA need to be the master? I'm not in the mood to wipe and reinstall everything right now.
    Mike
  5. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,788
    498
    9,110
    No, your motherboard's BIOS settings should allow you to specify the primary boot-up device.
