Question about running speaker wire
Discussion in 'Home Theater Projects' started by Pamela, Sep 14, 2003.
  1. Pamela
    Pamela Supporting Actor
    Mar 14, 2001
    779
    Not sure which forum this goes in...
    I moved all of my HT equipment to the house today. I'm having a hard time figuring out how to set it up. The house was built in 1933—not HT friendly at all. The position of the rear speakers requires me to run the speaker wires over the doors. Not usually a problem, except there are no door frames to run it around. And to top it off, the walls curve on the edges around the door. I'm stumped at how to run the wire. Pulling up the carpet is not an option.
    Any suggestions?
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Paint the wire the same color of the ceiling and staple it?
    Ok, the curves might be a mess. Super glue?
    How about poking a hole or two? If you can get to the floor below and then string it through. Sometimes, in a corner you might even find where the boards (Walls & floors) don't meet anymore, and might be able to pull the floorboard out and drill a hole at the end of the floor. The floorboard would cover the hole and if you don't nail the floorboard all the way back in, the wire won't slip and won't be p;inched, either.
    Hey, you moved! Nice going!
    Glenn
  3. John_Berger
    John_Berger Cinematographer
    Nov 1, 2001
    2,489
    Is a wireless speaker configuration an option for you at this point? (I know you just moved, but still...) It's certainly nowhere as cheap as speaker wire, but it's a good option if you don't want to have blatantly visible wires all over the place.
  4. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    what is directly below the HT room? crawl? garage? other living space?
    I drilled holes through the floor and ran mine in the crawl, a good way to go if this is an option.
    if you have carpet I bet with an electricians fish tape you could get the wire run under the carpet and guide it to the other hole and thread the wire this way, I've never done it or am even sure it could be done, just an idea (that I do think might work)
    look at the bright side, under that carpet might be some beautiful old hardwood floors just waiting to be discovered [​IMG]
  5. Pamela
    Mar 14, 2001
    779
  6. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    Maybe a member near by will be able to help, it really is no big deal aside from the dusty nasty crawl space, I don't even WANT to know what it's like in a house that old, blech. But if you want to pick up roundtrip airfare to LAX... [​IMG] it's cheaper to fly me out of colorado springs whenever you're ready [​IMG]
    the trick is to cut the carpet with a razor knife to slip the bit through so you don't snag it and run the carpet (learned the hard way [​IMG]) then just drill away. It really isn't that bad and keeps the room nice and clean, if only I could hide the fire hazard of wires behind my equipment rack as nice... Then theres my fish tank [​IMG] that is seriously a fire waiting to happen.
  7. John_Berger
    Nov 1, 2001
    2,489
  8. Dennis Nicholls
    Dennis Nicholls Lead Actor
    Oct 5, 1998
    9,018
    356
    9,110
    Boise, ID
    Dennis
    The problem with "wireless" speakers is that they really aren't "wireless". Instead of running a signal cable you have to run a power cable - this really isn't solving the problem when you want to put, for example, the rear surrounds up high near the ceiling.
    Pamela's house is probably finished with lath-and-plaster interior which is quite brittle. The only good thing is that there is probably more space in the walls for running a fish tape, and the house probably isn't up to current code with respect to cross-members between the studs.
    Is there access to the attic above the HT room?
  9. Pamela
    Mar 14, 2001
    779
    Anyone know how much professional installation to run the wires under the house would cost?
  10. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    Would using an electricians fish tape and flat speaker wire work to get the wire under the carpets? That's what I did in my home.
  11. andrew markworthy
    Sep 30, 1999
    4,762
    12
  12. Pamela
    Mar 14, 2001
    779
  13. Francois Caron
    Francois Caron Cinematographer
    Jul 31, 1997
    2,143
    Francois Caron
  14. Pamela
    Mar 14, 2001
    779
    Francis-
    Sounds like that would be my best bet. My wire has to go about 15 ft, too. Just don't want to mess up the carpet.
  15. Francois Caron
    Jul 31, 1997
    2,143
    Francois Caron
  16. Glenn Overholt
    Mar 24, 1999
    4,203
    As for pulling the carpet, it might depend on the installation. The pros stretch the carpet and then whack it down, so if you pull it up you may not be able to get it back to where it was before. That's the bad news.
    Of course, a regular installer might not have made such a tight fit, so it might be easy to do. I did have a speaker wire under the carpet once, but I didn't take the corner out. I moved down about five feet away (on both sides)from one corner. The sides were a lot easier to pull up. Then I fished a piece of stiff wire through until it came out the other side, with the speaker wire taped to the end.
    The carpet tacks are nasty, so stay away from them. If you do that the wire will be on top of the carpet tack strip and there will be a tiny bulge, though.
    Pulling the baseboards might be easier, as there is sometimes a space just big enough for a speaker wire (14 ga.) to fit under it. If it runs around a corner and the carpet tack strip is in the way, just chisel the corner out.
    Glenn
  17. Pamela
    Mar 14, 2001
    779
  18. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Pamela, why not just get a throw rug to put in the doorway area?
    My main system is in a living room with four doorways (no kidding; also built in the 1930s — personality!). Two of the doorways have 14-gauge wire across the path. Putting mats above them was the only solution I was willing to consider.
  19. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,751
    482
    9,110
    I've moved this thread into the HT contruction/interiors area (with a pointer still in the After Hours area).
