Question about rechargeable batteries
Discussion in 'After Hours Lounge (Off Topic)' started by NickSo, Jun 21, 2003.
  1. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Okay, i found some batteries and chargers cheap at compgeeks.com, one advertises:
    Ni-MH/Ni-Cd Battery Charger w/4 Ni-MH AA Batteries ($11)
    and the other is
    4-cell NiCd Battery Charger w/4 1.2V AA Batteries ($8)
    I just wanted to clarify some facts:
    NiMH (nickel metal hydride) has no charge 'memory' right? and NiCD does? So Ni-MH would be better right?
    Also, what do the mAH ratings mean? i know they're important, but i forget what they are. Is it low long they can hold a charge for? (ie if you used 1000mAH batteries it wouldn't last as long as if you used 1800mAH batteries in the same device?)
    Edit: also, how are these prices? how much does four NiMH batteries usually go for?
  2. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,828
    528
    9,110
    Yes, buy the NiMH rechargeable batteries. Just think of the mA rating as the capacity of the battery, so go with the battery with the higher mA rating.
    I think the current highest capacity is 2200mA NiMH batteries.
    3-4 years ago, I made an investment in 2 sets of 4 AA 1500mA NiMH rechargeables with the Maha recharger, and have have no complaints. The batteries are only used for my digital camera.
    I am thinking about picking up another set or two (of 4 AA batteries), though, for their extra amount of charge capacity.
  3. Mike Lenthol
    Mike Lenthol Second Unit
    Jul 28, 2000
    322
    On a similar topic, does anyone trust automatic rechargers? Back in the day a few blew up some batteries by overcharging, so since then I just use manual chargers, figure out correct hours and charge them when they are dead. Are there are foolproof automatic mechanism around now and how to they exactly work?
  4. Patrick Sun
    Jun 30, 1999
    38,828
    528
    9,110
    The little bitty Maha charger I got years ago was advertised as being able to monitor battery charge, and would go into either full charge mode when needed (or when you pressed the button for it), or went into low trickle mode to maintain the battery charge for each bank of 2 AA batteries. But in practice, once the battery charge light went from red to green, I just unplugged the charger (just in case...)
    I got mine from these folks.
  5. Mark Shannon
    Mark Shannon Screenwriter
    May 27, 2002
    1,991
    Mike, is it possible you put non rechargeable alkaline in the charger instead?[​IMG]
  6. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
  7. Jay Heyl
    Jay Heyl Stunt Coordinator
    Apr 19, 1999
    142
  8. Patrick Sun
    Jun 30, 1999
    38,828
    528
    9,110
  9. Jay Heyl
    Apr 19, 1999
    142
    Nope, it's not a typo. Look under "Batteries+Charger Combo". It's the first combo on the page -- at least it is for me.
    I've purchased from these guy several times and have never been disappointed.
  10. Patrick Sun
    Jun 30, 1999
    38,828
    528
    9,110
    Ah...there is it. Any idea how long it takes to fully charge up 4 AA batteries with that little charger? (Time is money, afterall).
  11. Jay Heyl
    Apr 19, 1999
    142
    Most (all?) of the battery chargers sold by Battery Space are made by Vanson. Going from the picture, it looks like that is the Vanson V-888N, which Vanson claims will charge NiMH batteries in 10-14 hours, though I would expect the newer 2000+mAh batteries to take longer. At $5.99 for the charger and four batteries, this is definitely NOT a sophisticated charger. At that price, it wouldn't surprise me if the thing didn't even shut off automatically. (At the rate it's charging, the lack of auto shutoff wouldn't be that big a deal. NiMH batteries can usually be charged at one-tenth their capacity (160mA for a 1600mAh battery) for more than a year without showing any damage to the battery.)
    If you want a fancy charger, Thomas Distributing is the place to go. If you want cheap but effective, Battery Space is a good place.
    I concluded it made more sense to go cheap on the charger and buy more batteries. Spend $6 for the charger+batteries and buy another two dozen AAs for $24. You're still $9 below what it would cost for the hottest new charger from Thomas (MaHa MH-C401FS) and you've got 28 high capacity batteries. Charge up a set of 4 batteries every day and you'll always have fresh batteries available.
