Alexis
- Feb 18, 2002
Hi,
What are the actual gains from a push-pull driver encloser like what M&K uses? Provided that you do not increase the enclosure size and simply the enclosure for a single driver.
I understand that the drivers will move air in the same direction so they do not cancel each other out, but what gains do you get from this setup? My thought is to either have a sealed box design with a push-pull, or a sonotube (sized for one driver) with another driver on top acting in a push-pull config.
