Question about Parasound Halo C 2
Discussion in 'AV Receivers' started by ArthurJ, Aug 5, 2004.
  1. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    I'm thinking about buying this pre/pro however I am wondering for 2 channel listening will I benefeit from getting the Halo P 3 preamp as well? Thanks!
  2. JackS
    JackS Supporting Actor
    Jan 17, 2002
    634
    Art- If you already have an amp you won't need another. If you don't, the Halo or any other amp of your choice will work fine.
  3. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    Jack, I was wondering if I would benefeit from getting Halo's seperate pre-amp for 2 ch. listening. [​IMG] sorry if I didnt clarify.
  4. JackS
    Jan 17, 2002
    634
    Art- Cost to benifit ratio here would probably be negligable. Unless your intent is to have a seperate music system in another room. Personally I wouldn't even consider it. Spend the money on a super nice CDP.
  5. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    Thanks Jack!
