ChrisPATT
- Jul 3, 2003
I have run out of digital inputs on my receiver and need to get a optical splitter and a couple cables - and I don't want to spend much money. I checked partsexpress and found this splitter for $5.80
partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=180-964
They also have several optical cables and I was wondering if there is really going to be much of an audible difference between these choices, or other ones on the site.
$2.80
partsexpress.com/pe/showdetl.cfm?&User_ID=16418278&St=2533&St2=-37638294&St3=-37487553&DS_ID=3&Product_ID=15990&DID=7
$6.50
partsexpress.com/pe/showdetl.cfm?&User_ID=16418278&St=2533&St2=-37638294&St3=-37487553&DS_ID=3&Product_ID=16146&DID=7
This will be used for a secondary dvd player that is used mostly for dvd-a/sacd (I have it currently hooked up with analog cables. My main player is used just for watching dvds - but sometimes I have to use the secondary one and I would like to be able to used the digital out.
I just wondering (since it is a digital cable) if there would be much difference between these.
Receiver is a Denon 3802 with Paradigm studio speakers.
Thanks for the help.
Chris
$2.80
$6.50
Chris
