Question about new brakes and squealing
Discussion in 'After Hours Lounge (Off Topic)' started by Bob_C, Oct 11, 2003.
  1. Bob_C
    Bob_C Agent
    Feb 5, 2000
    45
    Hey everyone,
    I have a 2001 Ford Explorer Sport that I just recently got new brakes on. Now my question is this... is it normal for my brakes to squeal after they were just replaced. They never squealed before I got the new brakes but now they squeal quite frequently. These new brakes seem to stop the car alot better than my old ones, they just seem to make more noise. Should I be worried and make a big stink at the garage where I had the work done or just relax about it.
    Bob
  2. Kevin Alexander
    Kevin Alexander Screenwriter
    Apr 17, 1999
    1,357
    Definately go back to the dealership and kindly request that they make it right. It is not uncommon for new brakes to squeal, but when done right, they don't. As a former Goodyear Tire Technician, I do recall that when turning rotors, if you take a power sander and do a light omni-directional skid on the rotors, it will eliminate the occurance of new brake squeal. Go back to them ASAP to avoid the "you-waited-too-long-so-we-won't-do-jack-w/o-charging-you-extra" scenario.
  3. Bob_C
    Bob_C Agent
    Feb 5, 2000
    45
    That's what I figured. I just didn't want to look silly when I asked them to fix something that wasn't broken. Thanks!
  4. dave_brogli
    dave_brogli Screenwriter
    Mar 30, 2002
    1,021
    thats right[​IMG]
  5. Zen Butler
    Zen Butler Producer
    Jan 24, 2002
    5,536
    18
    Southern, Ca
    Zen K. Butler
    Ford brakes are squeaky, it is one of those weird universal automotive truths. A non-directional cut with the proper grade disc should eliminate this noise for a limited time. My 02 still squeals on the right side.
  6. Vincent_S
    Vincent_S Second Unit
    Nov 29, 2002
    450
    They are probably going to tell you that they are semi metallic pads and squeaking is normal.
  7. Jeff Perry
    Jeff Perry Stunt Coordinator
    Jul 3, 2003
    89
    Yes they will tell you that it is normal and treat you like you're an idiot for even asking. Every brake job I've ever had done squeaked after the fact and that's the line they always gave me. I just started doing all my brake work myself. Mine have never squeaked when freshly replaced. Why, I have no idea. I just replace the pads, have the rotors turned, and put it all back together. Perhaps the "professionals" do it "better" and that's why they always squeak.
  8. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,145
    I own two older Fords and never had one of those "universal automotive truths" squeals.........
    There are anti-squeal coatings that are supposed to be put on the caliper/pad backing plates to prevent squeal. Other than the coating not being applied properly, sound like you didn't get a good rotor turn..........
    It is really very simple to do a brake job and NOT get squeal. The place you used just didn't do any "extra" and most likely didn't do the "necessary" either..........
  9. Armando Zamora
    Armando Zamora Second Unit
    Dec 22, 1998
    307
    I've done two DIY brake jobs in the past year. One was a complete rotor and brake pad change on all 4 corners of my passat and the other was just brake pads replacement on a dodge caravan. I have not experienced any squealing since replacing the pads on either car. I used a commercially available anti-squeal spray on the back of the pads just as Donny mentioned. The spray also acts as an adhesive to keep the pads against the calipers.
    Maybe the mechanic that performed the brake job doesn't or didn't use this compound.
