Question about my subwoofer, simple question I think...
Discussion in 'Archived Threads 2001-2004' started by todd stone, Dec 17, 2001.
  1. todd stone
    todd stone Screenwriter
    Dec 1, 2000
    1,760
    I have a powered subwoofer, connected using a coax. How come I have to crank the volume up real quick, so the bass kicks in, then lower it to my normal setting? If I dont bring it to a certain volume the bass does not turn on.
  2. JerryW
    JerryW Supporting Actor
    Feb 7, 2001
    640
    The powersupply on your sub probably has a "sleep mode" circuit and turns the sub off while it's not in use. The problem seems to be that your sub just doesn't know that there's bass being sent to it because the LFE signal coming from the receiver is turned down so low. Try raising the LFE/sub level on your reciever (and turn down the level on the sub). That should fix it. Or, you can just turn the sleep mode off if your sub has that switch.
  3. todd stone
    Dec 1, 2000
    1,760
    Hm I'll have to test it out, I saw it had a switch in the middle. it has a on, auto, off setting. It was on middle, so i put it to ON. Let's see what happens.
  4. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    I had the same issue with my SVS 25-31PC and, on the recommendation of SVS-Ron, just leave it on all the time.
  5. JerryW
    Feb 7, 2001
    640
    Yep, that's what's causing your problem. Raise the level on your receiver's LFE or simply turn the switch on the sub to "On". Either will fix your problem.
  6. todd stone
    Dec 1, 2000
    1,760
    yikes, now when I just leave it on, it goes BOOM when i turn the tv on [​IMG]
  7. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    todd,
    You need to use your receiver's speaker level adjustment facilities (pink noise for adjusting level of each speaker including the sub).
    Or, go buy a Radio Shack SPL meter and a setup DVD (AVIA or VE) and use these to set the correct levels of all your speakers including the sub.
    Use the Search command and FAQ here to find references on how to do this.
    BruceD
