Darren_T
- Oct 1, 2001
Since I calibrated my new Tempest with my system I have noticed the auto on circuitry doesn't trip until my volume reaches a certain level. While calibrating I turned my PE 250W amp gain up to about 10:00 and had to reduce the level on my receiver to -10 to -12. This combination doesn't seem to send enough of a LFE signal to the amp to turn it on until I reach moderate volumes. If I turn the amp to "on" it comes on and there is audible bass so I would figure the amp should turn on by itself. While troubleshooting I changed the configuration a bit. I turned the sub amp to about 9:00 or about 1/4 gain and then set my LFE level on the receiver to 0. This seems to turn the amp on just fine at the lowest levels and results in similar output.
Is this typical? Will my sub amp be under-performing because of this? I had assumed that any signal to the LFE would trip the auto-on circuitry. Am I mistaken?
Thanks.
Darren
Thanks.
Darren
