Question about in-wall speakers
Discussion in 'Speakers & Subwoofers' started by ToddP, Nov 20, 2003.
  1. ToddP
    ToddP Stunt Coordinator
    Sep 15, 2003
    172
    I have no experience with in-wall speakers. A friend is looking to get some in-wall speakers, and is looking for some suggestions. He's looking to keep it under $250 for the pair. Any recommendations and personal experiences would be appreciated. Thanks.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,185
    51
    9,110
    Katy, TX
    Wayne
    Without having any specifics, generally they are not so great for the main front speakers (especially in that price range). They have very poor imaging and awful-sounding bass, because of they cause the drywall to resonate. From a performance respective, using the speaker of your choice as a baseline, it'll take twice the money for an in-wall to match its performance.
    In-walls work well for the rear speakers, though.
    Wayne A. Pflughaupt
  3. ToddP
    Sep 15, 2003
    172
    Sorry, I should have specified. The in-walls will be used for his rear speakers.
  4. MichaelBarletta
    Aug 27, 2003
    33
    I'm using Sonance 622t for my main L&R and rear surrounds but they ran me $380 a pair. I wired before I sheetrocked and went with 5/8" board and glued it to the studs, then used a ton of 2" drywall screws. Check out their site sonance.com. They also have an awesome line of speakers in a lower price range. Hope this helps. Mike.
