William R
- Sep 22, 2002
I recently hooked my Panasonic Portable DVD Player (DVD-LS50) to my Sony 20-inch color television, Which is a regular 4:3 ratio tv, After conecting the player to the tv I entered the DVD Player's setup menu and changed the tv aspect ratio from 16:9 to 4:3 standard ratio since I'm connected to a regular tv, I noticed when I played my Star Wars Attack of the Clones widescreen DVD that the top black bar above the picture seems like its leaning toward the right of the screen and the top black bar isn't straight like the bottom black bar is, I switched the DVDs and put the bonus disc in and it also did the same thing, My friend brought over his Star Wars Attack of the Clones Widescreen DVD and it did the same thing with his discs,Also I noticed during some scenes in the movie there were some objects in the background of a scene that look squashed. Is this normal or is there something wrong with the tv, dvd player or the dvd itself?
