question about component video hook-up
Discussion in 'Beginners, General Questions' started by KenLeBlanc, Jul 1, 2005.
  1. KenLeBlanc
    KenLeBlanc Stunt Coordinator
    Jan 31, 2005
    117
    Newbie question...
    Hooking up a Panny SA-XR50 to a Samsung DVD player and an old Hitachi TV. TV only has RCA and S-Video inputs. I have the RCA going to the Moniter out on the receiver.
    I bought component video cables thinking I could get the best quality but I'm not getting a picture on the TV. I'm guessing that I can only use S-Video or RCA and not component ??
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    More often than not, receivers will not downconvert component to S-video or lower, as well as some do not let you mix types of connections at all - if it was s-vid in, it has to be s-vid out. Either case, it looks like it will not work the way you have it connected. If you don't need to do video switching, just go s-vid direct to the TV.
  3. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    If you did find a receiver that converted incoming component video from the DVD player into S-video to go to the TV, the quality will be S-video quality, not component video quality.
    The only way to realize the full quality of component video is to have component connections all the way to the TV.
    Video hints:
  4. KenLeBlanc
    Jan 31, 2005
    117
    Thanks for the info guys. Got it to work after picking up a few extra S-video cables. I did want the video switching as I think it's nice. System is all hooked ap and working good. Had a sound issue with the Digital Coax to the DVD player and then I remembered to check the audio settings of the DVD player [​IMG] Sure enough I had to make a couple of changes there and it was good to go.
