Dan Kolacz
- Dec 9, 1999
OK,
So I am thinking of getting rid of my ISF calibrated Sony 61HS20 and buying an Infocus 4805 or 5000 model.
What is the deal with running cables from the DVD player, Xbox, VCR, etc. to the projector if it is ceiling mounted?
Do you have to put your components on the side of the room or something?
Is there some type of 25 foot long breakout box I can buy and then plug all my components into that box?
What do you guys do?
