question about bi-amping using my HK 520
Discussion in 'Archived Threads 2001-2004' started by Thomas_Berg, Feb 16, 2003.
  1. Thomas_Berg
    Thomas_Berg Screenwriter
    Feb 28, 2001
    1,422
    Dallas
    Thomas
    i've been seriously considering trying to move to an external power amp for my main speakers (B&W 602's) but lack the $$ for purchasing a real amp. so, could i use the coolness of my HK's preouts/main-in's to bi-amp my speakers?
    i was thinking about buying two Y-splitters (male RCA -> 2 female RCA) and running them as follows: Y-out from Front L preout to main-in Front L and Surround L. same thing for the right side. then just run in 5-ch stereo mode and have bi-amped mains when i connect the speaker wire accordingly.
    my only concern is that if i play movies and it defaults back to 5.1 that it'll sound really messed up (or even damage the speakers) sending different info to the tweeters and the midrange woofers. will this work? opinions? suggestions?
  2. JohnSer
    JohnSer Stunt Coordinator
    Dec 4, 2002
    198
    The Y cables should work as you describe. You don't have to run in 5 channel stereo mode. The normal 2 channel will produce 2 Left, and 2 right channels of amplification.
    Unless you are going to do a bunch of wiring between music in HT, you will be limited in running in 3.1 and associated virtual modes in HT.
    I have contemplated doing a similar passive bi-amp experiment, but haven't tried it. Let me know if you think it makes an improvement in music.
    JohnS
  3. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    I would wait for another amp. I would be very suprised if the improvement was worth the effort.
    -rob
  4. Thomas_Berg
    Feb 28, 2001
    1,422
    Dallas
    Thomas
    maybe i should try bi-amping one speaker this way and leave the other one put and see if i can notice a difference? that could be fun [​IMG]
  5. Sunil_K
    Sunil_K Auditioning
    Jan 20, 2003
    Taking this thought further... I have a separate 2-channel amp powering the front bookshelf speakers via the pre-outs of a HK-525. Would it make sense, to connect the woofers of the front bookeshelf to the separate amp, and the tweeters to the output of the reciever? This would be bi-amping the woofer + tweeter. The details about the amp is that it is a carver tfm-35, and the bookshelf speakers are boston acoustics vrm-60.
  6. Rob Rodier
    Jul 11, 2002
    538
    Might make sense. However, what if the carver has a sweeter top end? The amp might be superior enough to make the biamping counterproductive. Also, leveling the outputs can prove to be difficult.
    I would imagine that using the Carver alone would yield better sonic results.
    I could be wrong.
    -rob
  7. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    In my experience passive bi-amping using a good amp for part of the sound and a receiver-level amp for the rest of the sound did not work out well. The advantages of the better amplifier outweighed the advantages of bi-amping in that case. But, give it a shot. It can't hurt.
