Question about bass and treble control on receivers.
Discussion in 'AV Receivers' started by Blashy, Jan 25, 2004.
  1. Blashy
    Blashy Agent
    Jan 20, 2004
    31
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    33
    Katy, TX
    Wayne
    Blashy,
    Look up Sherwood’s website – you should have no problem finding out there if the receiver you’re looking at has bass and treble controls.
    The second link is for some kind of decoder. Don’t know what it is or what it’s for, but I’m pretty sure it won’t replace a receiver.
    Yes, you can use a receiver with active (powered) speakers. Just look for one that has pre-amp outputs for the channels you’ll be using the speakers on.
    Wayne A. Pflughaupt
  3. Blashy
    Blashy Agent
    Jan 20, 2004
    31
    Thanks for the info.
    I can't find the receiver on the Sherwood site, it is a late model...
    I'll keep looking.
