Question about balancing speakers
Discussion in 'Archived Threads 2001-2004' started by Leon C, Sep 7, 2002.
  1. Leon C
    Leon C Auditioning
    Jul 10, 2002
    14
    I got a new set of PSB Image speakers set up for HT
    (Image 7PT for front, 9C for center, 10S for surrounds)
    and was balancing them on my Denon 3802 using a SPL meter.
    Is it normal for there to be a 15db difference in the right and left front speakers? That is what it takes to get the same reading on the SPL. All other speakers are within 2db of the front right, but that front left speaker is really quiet compared to the other 4. Do I have a bad speaker or something?
  2. Craig Woodhall
    Craig Woodhall Supporting Actor
    Jul 11, 1999
    590
    I would hook another speaker to that lead and see if there is a difference.. It could be a bad wire/cable or speaker.
    Craig
  3. Leon C
    Leon C Auditioning
    Jul 10, 2002
    14
    I tried a different wire and tried switching right and left on the receiver and got the same results. It is definitely in the speaker. Is that enough of a difference that it is defective?
  4. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
  5. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Have you tried also swapping the left and right speaker physically (not just changing the connection at the receiver)? If it's the same speaker down 15dB you know it's a problem with the speaker. If it isn't the same speaker, then it's a room issue.
    But with that much difference my guess is a defective speaker.
  6. Leon C
    Leon C Auditioning
    Jul 10, 2002
    14
    I tried physically moving the speaker also, but knew that
    it wouldn't make a difference (with 15db, you can hear the
    major difference without an SPL, so it is way beyond the room acoustics).
    Glenn
