Question about anamorphic squeeze... (1 Viewer)
Matt Stone
Matt Stone
Alright, I've owned a 27" Wega for about two years now, and a friend and I were discussion anamorphic sqeeze the other day. I'm not an HT Newbie, and I know most of the technical info behind anamorphic sqeeze...but I got to wondering. How much does the picture quality on an animorphically sqeezed DVD on a 480i tv compare to something using progressive. Also...what work is going on inside the tv to "squeeze" more scan lines into a smaller space.
None of this is that important, I just wondered...
Allan Jayne
To squeeze more scan lines into a smaller space...
On the CRT(s) the TV circuits adjust the vertical sweep to go from 12% to 87% of the way down the screen instead of 0% (extreme top) to 100%. The 480 lines' worth of picture are drawn in the same way as always and they will now all land, hopefully equally spaced, in a 16:9 shape.
Video hints:
RyanDinan
About the PQ difference...
An anamorphic transfer has nothing to do with progressive scan - although both will improve the quality of the picture. An interlaced TV can squeeze the scanlines into a 16x9 raster area and gain the same benifit of added vertical resolution (33% more).
A progressive scan TV will allow you to gain the benifit of a more stable image, and better de-interlacing of most film source through 3-2 pulldown detection (either in the DVD player or through the TV's internal circuitry).
-Ryan Dinan
MitchellC
Grip
This isn't really related to the subject, but I thank you because I've always wondered how a 27" would fit in that entertainment center (it's the same one I have, mine seen here)
Matt Stone
Matt Stone
That's the exact same entertainment center that I have. Check out this pic:
Link Removed
Matt Stone
Matt Stone
God...I didn't read your post that well now did I :D ...gladd I could help.
S205449
