RussKon
- Oct 31, 2002
Bill,
Surge-X does provide whole house solutions...although that doesn't help if a surge and/or emi interference originates in your house...other household appliances can cause problems in your audio/video/computer gear....
Mary and Chu,
Surge-X (a series-mode protector like brickwall) DOES NOT require ground connection to operate properly...
The following is a quote from the Surge-X website:
"SurgeX Series Mode surge suppressors act first as low pass filters which simply block the high-frequency (HF) components of powerline surges. The remaining low-frequency (LF) surge energy is diverted into a bank of capacitors where it is stored for the duration of the event and then slowly discharged back across the incoming hot and neutral conductors without involving any connection to Equipment Ground. SurgeX Series Mode surge suppressors can thus be placed anywhere along a power circuit without the ground reference elevation disadvantage of Shunt Mode surge protection devices."
Additionally, the inrush current after a power outage has been mentioned several times in this thread...Surge-X has incorporated I.C.E. (inrush current elimination) in many of their products...In addition to protecting your components after a power outage, it also allows you to power up several large amplifiers without the high initial current draw that can blow a normal 15 amp circuit.
Russ
www.surgex.com
Mary and Chu,
Russ
www.surgex.com
