Quality external A/B switch
Discussion in 'Archived Threads 2001-2004' started by David_Stein, Feb 27, 2003.
  1. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    i have an onkyo 575x and jbl nsp1 plus a pair of n26s. the pair of n26s is being used as the mains and one pair of n24s is being used as computer speakers (i live in a dorm room).
    the problem is that with the internal A/B switch in the onkyo the B speakers can only be set to large, there is no way to be able to use bass management and obviously the n24s cant really be used full range.
    right now i just have the b-speakers wired through the speaker level inputs of my powered sub (pb10) and switch back between linelevel and speaker level inputs depending on what speakers i am using.
    however, i will be getting a new sub (used 20-39cs+) very soon and the outboard amp does not have speaker level inputs.
    i dont really want to keep the old sub around just for the speaker level inputs so i am hoping to find a quality A/B speaker switch so i can put but sets of "mains" on the A-speaker outputs of the onkyo. i looked at partsexpress and radio shack and found that either the switches used spring clips (doesnt seem to be high quality) or were fairly expensive and more than what i need (like a 4 sets of speaker switch).
    is there any relatively inexpensive but fairly high quality (considering i only use an entry level onkyo and jbl n-series) a/b switch i can buy?
    sorry for it being long, but i figure its better to not have people asking questions later about the setup.
  2. Charles Gurganus
    Charles Gurganus Supporting Actor
    Mar 2, 1999
    689
    David, a company called Niles makes a good A-B switch (PS1 maybe) for around $40. Do a search on Niles and you should get some hits.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
  4. SkiingNinja
    SkiingNinja Second Unit
    Aug 14, 2001
    311
    The Adcom GFS-3 is very good as well. Onecall carries them...
    Sean
