Quad Sheilded RG6
Discussion in 'Archived Threads 2001-2004' started by Roy Wallace, Jan 10, 2002.
  1. Roy Wallace
    Roy Wallace Stunt Coordinator
    Nov 17, 2001
    108
    Hello again:
    In your opinions, how does the Radio Shack Quad sheilded RG6 coax compare to something like a higher end cable?
    I can get Liberty brand pure copper QS for $2.00CAN a foot, and the RS QS is only $0.55CAN a foot.
    I have seen many postings here praising Radio Shack conductors... Is this a route I can have confidence in, or is the high end stuff WAY better?
    All I am going to use this for is to upgrade the cable TV coax throughout my new house instead of the coax the contractor will use.
    As usual, I appriciate all input.
    Take care
    RW
  2. Dave Gates
    Dave Gates Agent
    Jun 13, 2001
    39
    Roy,
    Personally, I do not care for Radio Shack materials or equipment. No concrete reasons, merchandise just seems cheep to me, so I do not give them my buisness. However, with respect to the coax, I went with Acoustic Research QS-RG6 from Lowe's Home Improvement, for all of my cable & satellite wiring. The 500 ft. spool cost $0.36/ft American. If you have Lowe's in Alberta, I would check there.
  3. Kevin Coleman
    Kevin Coleman Second Unit
    Jul 3, 1999
    495
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I often recommend Radio Shack INTERCONNECTS for modest home theater systems. This does not mean that I endorce the CATV coax. I've not been impressed with it.
    If you are going to the trouble of a whole-house re-wire, look into the "Smart Home" cable from CoastCom. It is a bundle of 2 Quad shielded RG6 coax cables, and 2 Cat 5 network cables.
    Run this stuff in a "star" pattern to every room to a central location in your house. Here is where you also run your CATV & DSS feeds. You put a nice splitter/amp for CATV and your computer hub here as well.
    For the splitter/amp, look into a line of products from ChannelPlus.
    For the computer connectors, look into the line of products from Panduit. (They are inexpensive and you can wire them with a pair of pliers).
    Good Luck.
  5. Roy Wallace
    Nov 17, 2001
    108
    Thanks for the comments, everyone.
    RW
