QSC RMX 850 power amp (1 Viewer)
Martice
I am selling my QSC amp that I used for my sub. I am willing to part with it for $120.00 Plus Shipping!! .
Please see my sellers rating over at www.audiogon.com under my HTF user name "Martice".
http://cgi.audiogon.com/cgi-bin/fb.pl?user=Martice&&&&
I will take Paypal and Money Orders. .
Item is in perfect condition with a minor nicks on the bottom of the unit.
Good Luck and thanks in advance.
Specs:
8 ohms: 200W
4 ohms: 300W
2 ohms: 430W
8 ohms Bridge Mono: 600W
4 ohms Bridge Mono: 830W
Signal to Noise (20 Hz-20 kHz): 100 dB
Distortion (SMPTE-IM): Less than 0.01%
Input Sensitivity @ 8 ohms: 1.15v (+3.4 dBu)
Voltage Gain: 31.6x (30 dB)
Output Circuitry: AB
Current Consumption (1/8 power pink noise at 4 ohms @ 120VAC,
both channels driven; multiply current by .5 for 230V units.): 5A
Weight (Net): 35 lbs. (15.9 kg)
Distortion (typical):
20 Hz-20 kHz: 10 dB below rated power: Less than 0.03% THD 4 and 8 ohms
1.0 kHz and below: full rated power: Less than 0.03% THD 4 and 8 ohms
Frequency Response:
20 Hz-20 kHz, ± 0/-1 dB, -3 dB points: 5 Hz-50 kHz
Damping Factor (1 kHz and below): Greater than 300 at 8 ohms
Input Impedance: 10 K ohms unbalanced, 20 K ohms balanced
Input Clipping: 10 Vrms (+22dBu)
Cooling: Continuously variable speed fan, rear-to-front air flow
Connectors (each channel):
Input: Active balanced; barrier strip, XLR, and 1/4 in. (6.3 mm)
TRS tip and XLR pin 2 positive
Output: "Touch-proof" binding posts and Neutrik Speakon
Controls:
Front: AC switch, Ch. 1, and Ch. 2 gain knobs
Rear: 10-position DIP switch
Indicators:
PWR-ON: Green LED SIGNAL: Yellow LED (1 per channel)
CLIP: Red LED (1 per channel)
Amplifier Protection: Full short circuit, open circuit, thermal, ultrasonic, and RF protection. Stable into reactive or mismatched loads.
Load Protection: Turn-on/off muting, AC coupling (850, 1450), triac crowbar (2450, on each channel)
Dimensions:
19 in. (48.3 cm) rack mounting, 3.5 in. (8.9 cm) tall (2 rack spaces),
15.9 in. (40 cm) deep (rack mounting to rear support ears)
Power Requirements: 100, 120, 230 VAC, 50-60 Hz
