Jack Gilvey
- Mar 13, 1999
I just had to experiment. Fwiw,I'm using an Onkyo 575x receiver.
I calibrated to 85db using Avia. This was with my master volume set at "+10", since setting it at "0" didn't leave enough gain in the individual adjustments (only go to "+12") to get to 85db. After calibrating to this level, I found that lowering the master volume to "0", or a 10db decrease in level according to the master display, did indeed result in a 75db reading on the SPL meter for each channel on Avia's tones, or "ref -10db" so they do seem to track quite linearly.
So, now I know where exactly "reference" level is. Like I said, I listen at 10db below this (which is now "0" on my display, although I knew where it was before also). I found it important to know exactly where this "comfort level" is, so I can set it when putting in a movie and know things won't be too loud or too soft.
Interestingly (maybe just to me), playing the Onkyo's internal test tones on the system calibrated to reference (85db with Avia)showed them to be "recorded" approximately 5-6db lower than Avia, and also read slightly different relative channel levels. In addition, the THX Optimode tones on my Phantom Menace DVD read about 5db lower than the Avia tones. So, as with Phil's findings, my internal tones seem to basically jive with the Optimode tones, but not with Avia. In short, when Avia reads 85db, the other sources read about 80db.
[Edited last by Jack Gilvey on October 25, 2001 at 10:39 AM]
