pyramid foam DIY sound panelling
Discussion in 'Home Theater Projects' started by Shane Morales, Jan 4, 2004.
  1. Shane Morales
    Shane Morales Second Unit
    Jul 9, 2003
    433
  2. Rogozhin
    Rogozhin Stunt Coordinator
    Dec 5, 2003
    142
    Shane
    Wonderful suggestions and links-I'm there [​IMG]
    rogo
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Shane - outstanding website [​IMG] I'm sure this will generate a lot of attention.
    I just looked at the rest of your web site. The pictures of your HT room look great as does your DIY panels.
    I hope it will inspire others.
  4. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    Hey Shane,
    Did you try one of those panels on the ceiling? At the first reflection point of the center and mains?
    I always bring this up because it seemed to make the biggest improvement in my setup. The dialog is so much cleaner and well defined and it levels out the soundstage for two channel listening.
  5. Shane Morales
    Jul 9, 2003
    433
    Thanks Bob!
    James: no, I haven't tried the ceiling yet, but I will soon. I didn't order enough foam panels from partsexpress the first time around - not sure what I was thinking. I have the hardboard and hanging thingies ready to go, just not enough foam.
