PVR 501 Software Upgrade
Discussion in 'Archived Threads 2001-2004' started by Basil Kazepis, Jul 4, 2001.
  1. Basil Kazepis
    Basil Kazepis Auditioning
    Jun 23, 2001
    10
    I heard talk of the software being updated for the 501, anyone hear about when? I thought it was supposed to be by the end of June which has come and gone.
    Basil
  2. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,296
    53
    9,110
    Mississippi
    The upgrade happened at the end of June. Do you leave your 501 turned on all of the time? It must be off to receive the upgrade. The guide info is now stored on the drive and there are more than 10 timers. The downside is that about half the people lost their recordings during the upgrade. Check out the PVR forum atwww.dbsforums.com for the latest info.
    -Robert
  3. Basil Kazepis
    Jun 23, 2001
    10
    How can I tell if it has been loaded on my PVR?
  4. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,296
    53
    9,110
    Mississippi
    Press:
    Menu 6 1 3
    you should see various numbers.
    You should see one that begins with
    P115 or p116 OR P118
    P118 is the current version.
  5. Ken Stuart
    Ken Stuart Second Unit
    Jan 31, 2000
    468
    The upgrade included duplicating the Guide information on the hard drive, so that there is no longer any "please wait or cancel" messages, and you can move around in the Guide virtually instantnaeously. And, the PIP in the Guide now shows the current channel continuously.
    The other major change was increasing the number of timers from 10 to 50.
    And also, the list of recordings now shows the title and info from the longest program in each recording, rather than the first program.
    And, a few bug fixes were included, such as a fix for freezing and audio dropouts in playback of recordings, and a fix for some consecutive timer issues.
