Matt Weyen
- Mar 5, 2002
I'm on a VERY tight budget and want to build up a very cheap, but quality sub. My dad a head city engineer and can get ahold of just about any size PVC pipe I want. I told him that a piece of 15" wide pipe by 3ft long by 1/2" thickness would be about right. Now I just need to find a cheap driver (which shouldn't be too hard since car sub drivers are plentiful at the local pawn shops). As for tools, friends and family can cover all that. I can afford stuff like end caps and glue and what not. Here is the major question as to my $$ savings, I have a little shelf speaker system (philips) that can put out 175 watts that I don't use anymore. Can I run the sub out on my reciever to the auxilary in on the shelf reciever/amp and then run the speaker's out to my PVC sub? If I can't, this project could take considerably longer to complete.
Also, I was wanting to hear more thoughts on PVC than what I found in the last thread about it I found in here. I have read that putting insulation or pillow filling in the sub will greatly reduce resonance and/or standing waves (a little unsure if there is a difference). If I put the filling in between the 3 metal rods I plan on putting in to tighten up the endcaps, will PVC likely sound pretty good?
Thanx for any and all replies
